appreciate your input, I’m concerned because I current have 2 bricked VESC X’s that have not successfully updated their firmware without fault. One of the VESCs literally won’t actually update. I was able to update the other, however after the update it no longer detects or powers motors. It was working with the outdated firmware, but after updating it no longer works.
The thing with loctite being in the wrong places is that you can unintentionally damage other components trying to get it hot enough to remove. For example, I purchased a board where the motor pulley was loctited to the shaft, and after heating it up for a whole 3 minutes till it would finally budge, I accidentally bent one of the retainer rings getting the pulley off and the ring ended up falling off. Now i need to wait for a new pulley,
Also the nut holding the wheel on the axle was over tightened and I can’t remove the wheel/belt without removing the motor mount, which is heavily locticted and I’m damaging the wheel, belt, and motor cables trying to get the set screws hot enough to remove.
