So thats the end of it ?
Yup
Dammn thats to bad , 10mm shaft with bigger bearings, 8mm end shaft for pulley ,.wonder what company was making them ??
What is the sensor conector for VESC ?
VESC or focbox?
Focbox hehe
2mm JST 6 pin
No I think 4.12 vesc is 1.5mm pitch
And focbox is 2mm
To bad they are 170KV instead of 190Kv
They customize kv for you
Just for 2 ,…or at what cost?
You need to buy 4. And its like 65$/pc shipped for 4 pcs
edit your in Canada might be a bit different for shipping
This model also looks like Kaly.nyc motors he was selling …So this original seller was making about 100% profit
Dammn Sealed Maytech’s are about $100.00 each
makes you wonder how much it really cost to make a stuff huh?
Probably much less but this concept applies to every item your purchase
Actually OP upgraded many of the specs. I think his unit cost was significantly higher. And I believe he tested each motor, and had parts for repair?
I bet he wouldn’t mind of someone else did another run with his specs.
idk, one of my motors has a sensor issue and won’t detect. I think the only thing that he did was changed the bullet size?
