I just had some time searching in the wide, wild Lipo section of Hobbyking for something new.
And I found these:
Currently out of stock, but I think this would be one of the cheapest and best ways to build a pack!
6600mah 2S 65~130C for 21€?? What??
What are you guys currently buying, Lipo-wise?
Have you found something similar?
It is not much cheaper (imo)…
VTC6 ~ 5€ - 3120mah
2S2P = 2S 6240mah
2S * 2P = 4 cells
4 cells * 5€ = 20€
So the difference is not that big…
PS: i have bought Zippy Flightmax 6S 8Ah ~ 60€ (when it was discounted)
You´re right, but I´m only talking about Lipos here.
And I have my next Trampa 8S setup in mind, so I need cells with at least 300A discharge rate (two 150A 8S ESCs).
So these high discharge cells are really unique for that pricetag ![:slight_smile: :slight_smile:](https://electric-skateboard.builders/images/emoji/twitter/slight_smile.png?v=9)
Nano Tech:
2S - 6.6Ah - 21€
–> 6S - 6.6Ah - 63€
Graphene
6S - 8Ah - 55€
I would highly recommend going through the bargain bin at hobbyking ![:wink: :wink:](https://electric-skateboard.builders/images/emoji/twitter/wink.png?v=9)
still only 15C!
Like I said, for people who needs juice on command ![:smiley: :smiley:](https://electric-skateboard.builders/images/emoji/twitter/smiley.png?v=9)
Put 4 in parallel and you are good to go ![:stuck_out_tongue: :stuck_out_tongue:](https://electric-skateboard.builders/images/emoji/twitter/stuck_out_tongue.png?v=9)
But yes, you are right. I should have read it more carefully -.-"
Just saw, the 2s2p nanotech is in stock again for EU peops!
63€ for an awesome 6s2p with 6600mah with tons of power!
