Do you need an anti spark plug if running two 5s in series or can u directly plug the series connector into the vesc?
yes you need. a XT90s will work well for this.
no you don’t need one. the spark makes sure you are ready to ride!
an anti spark plug would make it less
Hey thanks man, anyway to do this without soldering? Bc im not able to…
Or could i opt for an on/off switch instead? Sorry for the noob questions my first time doing this
if you can´t solder than a vedder anit spark switch or similar with pre soldered plugs would be your best bet, but if they don´t have precharge circut they will fail sooner or later. if you use a discharge bms with a build in switch that would work too.
Thanks, do u have any links to ones u would recommend.
Not really as i‘m not a fan of anti spark e-switches.
If you need an xt90s anti spark or a loopkey, maybe you can just post pictures from where it should be installed and which plugs coming from battery and which on the escs and somebody can solder you something.
