[quote=“nonstop, post:1, topic:12653”]
What kind of Trucks should I get? Caiber / Cailber II / Paris V1 / V2 / Surf Rods indeez / Liquid Attack Black Star / Alien Trucks
Whats the difference between all these trucks and does it really matter?
will any fit on the Vanguard Board?[/quote]
Depends mostly on what kind of motor mount you get. MOST folks here (DIY) go with Caliber II’s as the shape of the truck hanger gives you a solid mount w/o rotation. I ran v1 ADS mounts on Paris 195’s and did not like how frequently they rotated (and scraped on the ground). So personally i’d avoid round trucks. There are ways to fix or help prevent, but even easier is Caliber II trucks!
Both will fit Vanguard. No matter what trucks you get - spend the extra $ and get good bushings setup correctly for your weight! Makes a HUGE difference. Truly.
Which is better ABEC 11 or Orangatang Kegel?[/quote]
Vanguard has a lot of room for bigger wheels - so either. It’s preference and like asking if you like blondes or redheads better… I think there are more options using flywheel wheels and gears, so usually stick with them. Kegels are REALLY nice though and i’m setting up a pair to try out more. But you’re stuck with kegels if you go that route. later, rough roads, or want bigger wheels… no bigger kegel options, or softer, or smaller, or less $$$ clones (that i’ve seen). So with all that i’d suggest Abec Flywheels to start. Tried and true, and flexible down the road when you know more of what you like and want.
Can anyone recommend a 10s battery that would be suitable for the Vanguard? or maybe 2 x 5s? or 2 x 6s?[/quote]
Li Ion or Lipo? Budget for battery/batteries?
What kind of flex should I get? i’m 75kg[/quote]
[quote]Flex 1 (42"/107cm): 175-230+lbs / 80-105+kg
Flex 2 (42"/107cm): 150-210+lbs / 68-95+kg
Flex 3 (38"/98cm): 150-200+lbs / 68-90+kg
Flex 4 (38"/98cm): 120-170+lbs / 55-77+kg
Flex 5 (38"/98cm): 80-140+lbs / 35-65+kg[/quote]
I am a big guy and have 42" Flex 1. I like the flex, but still might stiffen it a bit.
Flex = PITA when you are building esk8. The best solutions i’ve seen are OKP and whitepony’s builds, and squad’s… When done correctly i think it looks better than Boosted!
25 is totally doable w/ almost any setup - look at some gear calculators. 15/36 is the most common (enertion’s kit gearing motor/wheel)
There is definitely a trade-off with flex. It does help with bumps, but it is not as capable toe-to-toe with a stiff downhill board at speed (everything else being the same - mostly dependent on skill). I’m not a downhill guy, so that’s just my opinion. I’ve yet to see a downhill race w/ vanguard being used.
There are a couple 3d printable enclosures for vanguard too i’d look at. You will want to separate your batteries and electronics with the middle bare to allow flex. I’m sure you know this, but just a reminder.
thingiverse link for 3d vanguard enclosures. credit to creator!
I know it’s a lot of info - HTH and GL!
