hey i just got a sumer job that wil make me around 400 euro and whit that money i rly want tho build a second electrick skate board i have a 11s 16000mah battery or around 200 2000mah 18650 1-5c.
i have a board that i love and that i woud like to covert in to a elcetrick one http://www.streetsurfshop.nl/nl/flying-wheels-flying-wheels-mustang-sally-lime-lon.html
i have no clue what to use as a motor/motors and esc
i woud like to have in hub motor but if there are rly big draw backs oone those plz let me know.
if any one coud help out that woud help a lot
i have a good rage of tools btw just in case
You should have a look at other people’s builds on the forum and see what they have used. The large 11a battery should be fine to use as long as it can supply enough amps and you don’t weigh a lot. You could also use a vesc as the esc but make sure you read up about that so you don’t blow it up. The motors you should look at are some sleep: motors from HobbyKing if you are going to use a belt or chain drive. As for hub motors I don’t really know much about them just that they don’t have a lot of torque
i have a okay AT i like it for off road a lot, but on the street its pure shit that is wy i am looking in to a street build whit 90mm wheel hope to get around 30 mph if that is posibele dual motor (i way 60kg btw)
i am looking at the sk3 - 192 kv
any sugjestion for a gear ratio
tnx
where i ride the bigest hill is like 10% so dont need a hill climber just flat
