if any one has a abs style plastic enclosure for around 30aud that would be nice, needs to fit a 10s4p, single vesc and decent size bms
https://www.bunnings.com.au/protite-250g-fibreglass-resin_p1560650
https://www.bunnings.com.au/protite-fibreglass-0-5-x-1m-woven-cloth_p1560658
https://www.bunnings.com.au/monarch-250ml-pro-renovator-measuring-cup_p1662151
https://www.bunnings.com.au/paint-partner-38mm-synthetic-paint-brush_p1662328
https://www.bunnings.com.au/british-paints-310g-spray-easy-flat-black_p1580896
there’s your enclosure. all under one roof. after all this is a diy forum
what do you think of using a plant tray as a base and then strengthening it with carbon/fibreglass sheets
if you want? not ideal but you can
Cheapest I’ve seen for this enc. I’ve been looking since i found it fits 3x graphine lipos
I have use this with an OG skateboard build fits a 10S3P battery, bms & 6.6 & Dickyho mount but had to lose the internal walls.
Damn dont buy fibreglass from bunnings, that shit is like 10x more expensive than it should be. Find a local supplier or order online
