I’ve upgraded to 97mm wheels for a smoother ride and the board doesn’t seem as strong of pull and seems to have more voltage sag on the battery. I’m wondering if a gear change would help with that?
If anyone has experience changing the gearing for larger flywheels I would be interested in what you are running? Also would this help cause less of a drain on the battery?
Basically, I have a Raptor V1 on a different deck with 97 Abec 11 Flywheels. I find it still very powerful compared to other boards, but I’ve noticed that the battery drains very quick. Real world range is not better than a Bamboo GT (10-15 km here in Sydney) but I can still ride when the Evolve Eco drop kicks in
I am running the original setup with (15T/36T gearing)
Yeah I’m starting to think my battery is just dying. Wondered if an increase in teeth would help avoid the voltage sag that causes the vesc to shut down
