I just figured out that my xt60 is making a little spark with a little noise when I plug it in, after that everything seems to work without problem, no more spark, the voltage on my indicator works and my receiver led is on (I didn’t tried the motor for the moment) so my wires should be good, no + - inversion or something like that.
8S 1P battery, so 33.6V and 50A (Max VESC).
Fine except will carbonize the plug contact. Only the xt90s has the integrated anti spark feature w a resistor that connects first. I’ve heard of using Vaseline or other nonconductive paste on the plug so when almost connected there’s no relatively low resistance air between the contacts and then no spark. Or just keep sparking and get new plugs when they get covered w burn marks as they will have higher electrical resistance then
I’m curious about having an exposed wire like that in the system. If let’s say you had wet hands and were to touch that bare spot when doing a lot of current how would that go? You would become part of the circuit and I guess a bit of current would flow through you based on ur resistance. Ud be an auxiliary high resistance path. Wonder if anyone has gotten a shock by not being the sole path but on the side like that.
But if it weren’t. Jumping wouldn’t work (don’t knoe ur serious and this isn’t ac that could go to ground)
Wonder how the electric would travel if say you connected a giant aluminum block even to the side of that loop key wire. I imagine the current would utilize the complete aluminum block or you’re entire body So could u get a deadly shock through the heart even though only touching the different polarities w your one hand.
