i’ve only seen the term “lost pla” mentioned once in this forum so i thought i’d share this.
Could be used for pulleys.
It’s like when Grant Thompson puts foam in his forge and pours molten metal in.
exactly. I dont have a forge so this isnt in the cards for me but i’d like to see someone try. Ill print out some pulleys if someone has a forge
I certainly appreciate the craftsmanship!
I didn’t know you could do that with PLA. Very cool!
Microwave forge. Better to not do lost pla but make a silicone mold of the pla part as apposed to being able to cast only one. and cast low Temp metal. I forget maybe it was sychotiller who made a mold and was casting resin parts Smooth-on has a bunch of silicone that can do high temp. Not sure what temp u need to melt aluminum or maybe do a bronze
cast low temp metal directly in the silicone?
You can. Smooth-on is an easy source and likely are at a local art store or online. Can’t get sychotiller’s name to come up but he’s done casting of pulleys @psychotiller
