![:smiley: :smiley:](https://electric-skateboard.builders/images/emoji/twitter/smiley.png?v=9)
Looks good so far! Looking forward to seeing more pictures.
Looks awesome! Glad I could inspire someone. Keep it up!
Here is a Video of the building with the enclousure (Normal Tupperware)
Mine BMS don’t arrived so I bought a IMAX B6 and I’ll do the VGA trick
Update
Hello guys, I noticed some mistakes in my build, first was that Imax b6, It was overcharging a cell and than I returned to the seller and will buy a Bms! Other one is that I change to kegels
But I need to make new holes in the pulleys, this build is driving me crazy!
Other upgrade is on the motor mount, on the other one the Iron Plate Bended and now I will do a plate on a Plasma Cnc and it will be more professional, but I want to do a all new mount from zero, but the guy at the Cnc said that the Normal Aluminum wouldn’t not work for a motor mount, he said that is it a Pan Aluminium, so I’m a bit afraid, can you answer me?
the New plate is very thickerNew update. First I want to talk seriously about wiring a BMS, I tought it was easy, but it is pretty hard because the Alien’s Bms is not as the Bestech one. So I will use another Imax B6.
New Pulley
Remember that I said that my pulley was made out of steel? That pulley was pretty wobble, so I made a design of a Kegel XL pulley and printed with PETG, here is a picture
It works pretty well, just missing one bolt, but I saved 1kg just changing the pulley.
Motor Mount
Another problem that was giving me headaches was the Motor Mount, the one that I couldn’t do my self, so I bought one from Alien.
But Bruno missed the clamping ring and I will 3d print one now.
Also I made a new enclosure out of aluminum, and It works pretty well and I’ve put tape in it to avoid shorts Hehe
New Shape and Cables Guide
I ordered from a Brazilian company that sells to USA too a new shape, just want to share it
and I printed @mmaner’s Cables Guide and will retire the velcro
