based on but I designed it and printed first. Then use the printed one for a bad fiber glass work but was my first one. Solid as a rock though. The STL file in on thingverse but I am going to release the step file as well on the thread that @moon recently created. ahahahah really fun I just posted about it and you aske me of the enclosure. Cool!
Ok thanks @ervinelin for the pulley file. That made thing way easier. I only had to modified a bit to fit my DD. First try I didn’t think enough about the bolts position but now it’s fixed. Waiting the new 60Kv motors and deck to make it happen!
Final version
@deucesdown I will send you the file once it’s tested. I think the 3D printed version is plenty for this pulley. As long you can print it in PETG or ABS or better nylon. 6-7walls, 100% infill.
I will make a thread alone for the new deck and build, but finished the enclosure too. I will build a DIY vacuum forming (or at least try) and use 3D printed mould for it. It should be fine for few tries.
Choo choo! I have bergmeisters on hand, can print and test fit. I have nylon on hand but haven’t tried it, mostly due to the dry storage thing. It’ll be PETG for me.
That enclosure… mmmmm.
Enclosures always been the most tricky part of the build for me… I hope your vacuum former works!
I know about nylon. I am making a diy heated box for it. Recently saw Filadry. Check it out. If it does what it says is pretty pretty awesome and Amy grab it. Once parts are here I will test it and send the final adapter
Yeh I hate it too. That’s why for one of the deck I went for integrated enclosure. But this one is semiontegrated, damn…difficult part of vacuum is find the big ABS sheets
Ok I think it is right now. I will send you the file @deucesdown @pookybear so you can be prepare for when you get the drive. You will need 3 M4x30mm and 3 M4 x 12mm each side to lock them in place. Always screw in a star configuration. I will double check the screws leght but should be correct. Too long risk to damage the winding inside the motor.
What are the dimensions of that can?
The actual can is the same of a 63mm motor need to check the exact diameter. The one I made to cover the screws 76mm. It has only aestetich purpose.
Looks really good mate! Can’t wait you get your motor, really want to know more and a comparison of those 75 VS 60kV !
DD kit are almost finish. Only logo left. Motors are done. Only PU sleeves missing.
I also can’t wait anymore. Yesterday I finished the vacuum forming… Ready for making the enclosure for it.
I want you to be my neighbor!
The process and everything seems to be perfectly made,
strongly following as usual ^^
Eh eh I would like to have you too. I used a fluvacuum. The one intends to suck out anesthetics during surgery. Got it from a disassembled lab. It’s rather strong and moreover silent since it’s made for surgery room. If it is not strong enough I will search for a workshop vacuum. I have no experience with vacuum forming so I need to try. Waiting the 3mm ABS
Finally the Choo Choo deck came… Really pleased with the result… Need to make the vaccum formed enclosure now!
Wow, looks strong and really really beautiful too, I think I have a preference for this one ^^
can’t wait to see you on this !
Yeh this one is simplier but I also like it a lot. It’s also less expensive to make it. The other one I guess will stay a single unicorn
Both of them feel strong. The short one is a little heavier since it’s almost full wood.
Nice board man! How much does it weight? What battery are you planning on using there?
Is that beautiful deck available for sale?
I will just move my spud hardware inside so 12s3p but can fit more. The cut out is pretty wide. I will weight both the deck asap.
Well it’s the prototype I made to go with my DD and hammock base plate. After I tried yes if people are interested I always make available my projects.
