Sure, it is not necessary I was just curious.
Following @Deckoz’s lead there was only one thing to do; bury the receiver and BT modules…,
But in the same single vesc enclosure, no what?
I had to bend pins and shrink wrap, worm things in and around around but hey I claim victory so far on this part.I put on @Ackmaniac’s F/W & ran setup again, now reasonably happy with it. One vesc had a bad motor temp reading which was not the motor, vesc thermistor is reading far too high.
May have to replace something which is a shame since I conformal coated them while I was at it. So to avoid a faulting vesc slave I leave the motor temp cable disconnected, the vesc can handle that without faulting you just see a wildly inaccurate negative value in realtime
I’ll rough finish to try and get out on Sunday
Do you think these covers will fit on TB 6355’s?? I just bought the Duplicator I3 and want to print EVERYTHING!!!
Fraid not but have a search common mount
what case is that?
Our first single vesc 4.12 casing
