That’s looking good! Please use some kapton tape or something insulating to cover the parts of the battery you have already welded so you don’t short the battery by accident.
My problem at first was that I got some bad welds when I put them very horizontal. Now I use them almost vertical, only with a bit of an angle. Maybe some more angle will help.
Now I have put it all in a 1150 pelican box and connected it to a 1040 pelican box with two focbox inside. Did water test in the shower without electronics first so I don’t have to worry about water when I run.
This has a layer of kapton between the layers of cable.
There are some improvements left to do, shrink wrap and so on. But it fits nicely in the box and no wires are squeezed. (It is possible to remove the battery from the box.
The battery box for now has 2 velcro straps below and one strap around to hold it.
The board works great, did some testing in the snow and on the frozen lake. The thing just goes!
Thx for all support esk8 forum, this forum has all you need to build a E-MTB.
