Hi all!
I’m brand new here but was wondering if I could solicit some advice from you experienced esk8 builders.
I was one of the lucky few to actually receive a functional Marbel board back in the day, and surprisingly, it has served me quite well for serveral years.
Recently however, I got caught in a downpour far from home, was late for something, and so had to keep going…ultimately, I believe some water got into the front switch opening and may have shorted out just the front part that housed the on/off switch, USB port (which i don’t really need), indicator lights, and the charging port. At first, it was still just flashing “error” lights after the incident, which I’d seen in the past before it just fixed itself on a full board reset. But this time it’s just stopped turning on altogether (probably because i can’t charge thru that port anymore, hence no more lights).
Pretty sure all the internal major components are in tact, but can anyone provide a newbie builder some advice on how to replace the component I mentioned?
Attached some pictures of the board and the front component in question for reference. Thanks so much in advance!
