@Deckoz thanks for the detailed assembly for the battery pack, didn’t think that you can put kapton before spot weld, can be a good insulator for the positive side, nicely done, Did you avoid using insulator (circle thing with adhesive) on the positive side? remember that @Kaly said that insulator are no good in case of short , glue might caught in fire( trampa caught in fire).
Insulators honestly make it harder to weld. As it raises the lip, making the chances more likely there’s an air gap and you burn a hole in the nickel.kapton is easy, adds all the protection I need for the welds and is nice and thin.
Insulators…meh…they just take up space…
So haven’t had much time to work on it. Unfortunately the model my friend made was more of an afterthought for me and didn’t end up fitting like I wanted. Which is ok. So resorted to the pass through unloosable loopkey.
All wired and charged.
Unplugged
Plugged
Close up of esc area
I also am resorting back to my TB Nano remote… Which is really depressing. Ack 3.100 firmware with a metr module and wireless VESC tool is something I don’t want to give up. And unfortunately the Photon doesn’t work currently on 3.100. So to the shelf it goes for now.
Also made a riser
Just made sure I had UART setup and was able to connect to the wireless TCP bridge and CanBus. Gonna try to finish bolting it up tonight or tomorrow morning…
It livessssssssss
Still need to extend my senior wires. But power
Came out great, congrats
Shoulder feeling a bit better…I mustered up a whole battery ride of 44 miles. Could sip another 2-4mi out of it if I felt like cruising around 10mph… this ride was with a 3.35/cell cutoff(43.5) and ended at 44.1 because of sag during hard acceleration.
Dude… 44 miles on one charge lol wow.
That’s awesome range for such a sleek build
It’s thin enough all the way down the board that carrying it belly down like I would a normal board. On my side is no biggie even though it’s a bear at 25-26lbs
… But the 65 degree front has gotta go… swapping for 44 base plates with a 6 dewedge in the front for a final 53/29 instead of 65/35. Lol 65 isn’t right
Doing final assembly on mine tomorrow, will start with 50/45 and feel it out Been doing 50/50 forever
Dude I rode this board 5050 analog dh for a few months waiting on the enclosure.
But powered it just isn’t right… I can’t shimmy my front foot around to leverage points like I can on every other board… Likely because 50 plates resulting in 65 degree nose on a powered rear feels fine…until you move your foot lol them any bit of torque shift from the rear just makes it flop.
I’ve already taken 6 off the front but I really need/want the front closer to 50 so I can move my foot. Lol I also like my trucks insanely lose… So it’s all ankle here lol…can’t handle the 65
My point is it is completely different powered above 25mph…
I keep it quite tight, got 96a pretty much everywhere, that’s to compensate the taller ride height I like. I seem to prefer the nonstandard lol. My first sk8 was an esk8, I can’t even push
This isn’t waterproof around the enclosure is it? Or will the final sealant application make it sealed
Geez I couldnt ride that lol
I was thinking of doing the gasket on the deck, seal around the mounting holes
It’s water tight except the nose where I added extra cells… So the battery keeps the nose raised about 3mm so that’s the foam in the last picture about the BMS…
I like to control the trucks not the trucks control me… Idk… It’s a weird relationship with angles of metal
Just noticed your gasket is on the outside of the mounting holes, should really add some on the inner side Or a wider one that’ll cover the holes too
Ah my screws have gaskets on them that are held flush by the sockethead dress up washers
And compresses
So I’ve swapped around baseplates and bushings and settled on 53/35
I’d call this done except thd blue nuts that are still Mia from China to replace the pink
Beauuuuutifullll
