Hey folks,
Long story short - I have an ACTON Blink belt version skateboard with a broken ESC.
I am going to use its parts to build a DIY skateboard. Right now I am expecting a Matytech VESC which I bought to arrive, and I am going to use the ACTON Blink motor and battery (with ACTON’s charging port and ON/OFF switch).
I am thinking about changing the motor in the future to 90mm Hub motors also by Maytech. In order to get top speed from it, I would like to know if ACTON’s battery pack is good enough to deliver enough power to it? I am kinda new to all this and the only thing I know about the battery (from searching in this forum) is that the battery pack reads 41.4 volts at a full charge, and the pack is 72 Wh (source).
Should I be okay? Or will I need to upgrade the battery pack to reach top speed? If so, to which one? And what do you guys think about these motors?
Thanks.
