Description:
Maytech brushless outrunner hall sensor motor are specially designed for electric skateboard. They come with low KV, high torque and efficiency. All parts are made of a high-precision CNC machining center, and all surfaces are made with oxidation treatment. High temperature and high purity oxygen-free copper wires were used. The motors use high-grade magnets and 0.2 mm lamination to improve efficiency. The hall-effect sensors inside tracks the motor’s position. This information permits the controller to alternate power with the right timing and in the right sequence and, voila, it spins.
Better efficiency means you get more mechanical energy per unit of power,
After a lot of development we have put together what we know works best for an electric skateboard motor and made it small and compact.
Model NO.: MTO5055-220-HA
Motor KV …………………………………220(RPM/V)
Shaft…………………………………………6mm
Stator size……………………………………Ф40.0X37.0
Motor Size……………………………………Φ50.0×55.0
Max. Current…………………………………30A
Input Volt. ……………………………………2-10S Lipo cell
NET Weight …………………………………270g
Max output Watt. ………………………………1170W
65$ EACH 5$ SHIPPING OR PAIR FOR 110$ FREE SHIPPING IN THE USA, PM FOR INTERNATIONAL
