mmaner
June 16, 2018, 4:07pm
1
Ive got a Maytech remote I got a while back. It died on me yesterday so I took it apart today. The positive lead from the lipo battery has pulled loose from the connector. Can someone ID this connector for me?
I want to get a replacement and resolder the battery side and get this thing running again.
thanks
Flor
June 16, 2018, 4:51pm
2
It looks like a 2 pin JST connector
mmaner
June 16, 2018, 5:04pm
3
Yep, but what size? It’s tiny.
Looks just like the ones on my (toy grade) quadcopters batteries. Like the ones used by Hubsan or Syma. Maybe their manuals will identify it properly?
mmaner
June 16, 2018, 5:09pm
5
I’ll check it out. Thanks.
You could just get a new (bigger) battery with the connector already installed!? I think all lipo’s of that size come with the same connector.
mmaner
June 16, 2018, 5:12pm
7
There’s not a lot of room in the enclosure but I’ll do some measuring and see.
What about soldering the battery right to the board?
mmaner
June 16, 2018, 5:29pm
9
I’d rather not. If I didn’t have other remotes I would, but I’d rather have it stock.
Do you have any pins? You could repin the existing connector.
Do you have a vernier calipers to measure the distance between the 2 holes of the connextor?
mmaner
June 16, 2018, 6:22pm
12
I may do that if I can’t figure this out.
mmaner
13
I have standard calipers, but none that will measure that small.
U try using a ruler. From the center of 1 hole to another. U can roughly gauge the distance. I should b able to tell you the specific jst connector with the rough sizing. It is either 1mm/2mm/2.54mm
mmaner
June 16, 2018, 7:54pm
15
It’s not a 2, so like it’s a 1mm. I’ll measure it when I get back to the shop… Had a chance to go ride so I took it
Sorry to go offtopic but do these maytech remotes have a super long distance connection range like the finger trigger mini remote (pictured) does?
mmaner
June 16, 2018, 11:08pm
17
It’s pretty long. I’ve gor 4 and have never had an issue until now.
Thanks man, i already have the mini remote but im just trying to decide if its worth switching to the meytechs since its rechargeable .
Jedi
June 16, 2018, 11:31pm
19
@mmaner if it’s a 1.25mm, I got you covered. Can send on Monday, just let me know.
mmaner
June 17, 2018, 12:04am
20
Hell yeah dude, you rock. I appreciate it.
