Hi
Does anyone know the length of axle a MBS Rockstar pro wheel needs to be properly seated? I’m thinking of running these on TB218 trucks.
Thanks
Hi
Thanks
How you plan to mount the rockstar pro hubs? You have 8mm bearings for them or you will use spacer?
I’ve found some 8x28x9 bearing
Would you mind to share the link where you found them? Maybe they have some bearings with 10mm there too? That’s what i‘m searching but can’t find.
