What I did was just buy a generic 10s bms and charge through it, but wire the circuit to discharge around it. Let me know if you want me to draw it out for you, but I think you’ll be able to see what I mean if you look at it. There are plenty of cheap bms’ on ebay, and since you’re discharging around it, the discharge rating isn’t a huge deal.
its just a basic bms… i killed my meepo bms from riding in all weather… eventually corrosion got to it…but the cells were fine…
3p your gonna need a new case anyways so what ever bms should work… if u were going 2p and trying to put it back in the same case then id say get a small rectangle one like meepo had.
or…reuse the bms and extend the wires if/where needed.
I would go for 10s2p with 30q. You would get 33% extra range. And you would get rid of voltage sag. While using the same enclosure, and not increasing the weight.
Bypassing for only charging means that you use the + and - of your battery and they go straight to your ESC, so you use direct power from your battery. So no current is going through the bms, so you won’t be able to break your bms by pulling to much current.
If you connect your bms for discharge, you will pull power through your bms which is connected to your battery. The thing is with a cheap ass bms, they can’t handle the high current and will break.
