Update 27-1:
Build is fully assembled, apparently I like working on electric skateboards better than studying for my exams. Who would have guessed. Only a few things left to do, #1 is installing the battery percentage display, I am missing the correct wire so until i get that in ill have to do without. #2 get a few extra bolts, stripped one during assembly and need to replace another because it is almost stipped. Anybody any ideas for some good quality m5 bolts? preferably torx because they just strip less. Added some pictures of the results.
Parts list:
Mindless makali SK
Orangatang caguama orange
E-caliber trucks
63mm motor mounts from @e.board_solutions
Wheel pulleys and motor pulleys (36-15) from @e.board_solutions
Flipsky 6355 190kv x2
Flipsky vesc 4.12 x2
Flipsky anti-spark pro
XT-90 loop key
10s4p 30Q by @Tijmen
Homemade enclosure
Hello, most things look good, but I would swap out the flipsky motors with some from Torqueboards or bkb:
https:///collections/electric-skateboard-motors/products/electric-skateboard-motor-6355-190kv
You don’t need both the loop key and the anti spark, as they both do the same job, but I would ditch the flipsky anti spark as well, the are pretty well known to fail. The vescs look good, as well as your BMS wiring. It is good that you did your research first lol. To answer your other question, it does not matter which wire you put the loop key on, both pos and neg will work fine
Beautiful Diagram! I’ve been scrambling trying to get myself comfortable with how to wire up the components and your drawing layed everything out in a way my brain can understand.
I have already got them here, if they fail I will probably swap them out with some maytechs.
I’m going xt-90 antispark for sure, i think ill just install the flipsky and see how long it lasts. my reasoning was using the flipsky for regular turning on and of and then pulling out the anti spark xt90 whenever charging, or when the flipsky fails
It’s the flipsky nano controller. Since I was ordering there anyway I just decide to order one of those. It’s 50 usd or something, maybe a bit less. I ordered the two flipsky 4.12 vescs from AliExpress for 55 usd each.
The latching switch stopped responding. It now sends power to the vescs with or without the switch like it’s constantly on. Only way to turn it off is by disconnecting the battery
