so I’ve finished my first build 2 week ends ago and I’ve ridden it without issue for the whole weeks after that.
I was riding it carefully because I didn’t have grip tape at first.
Last week end I took some time to go buy and put some on.
I also finalised the esc enclosure.
My first 2 rides after that were fine.
Since then everytime I went with the board I’m experiencing disconnections with the input.
As a precision, I noticed I bent the pins for the servo cable on one of my ESCs.
I thought it was that so I changed my ESCs from slave to master and vice versa so that the damaged pins are on the slave and not connected to the mini receiver…
Well that didn’t work. I tried pairing the remote again but that doesn’t seem to be the problem as they do pair, I only use the connection while I ride. Once it first disconnects it reconnects briefly but i can’t have a good connection ever again for this ride. Once I let the board rest for a few hours, I can ride for 2-10 minutes without issue and then it starts again…
This is very annoying.
Any ideas what could be the source of this issue ?
I’ve thought about it but dismissed it as I charged them full the week end I finished the build and thought they would go at least a month considering that I’m not riding that much. Also every time I turn it on they whole system works for 5-10 minutes.
I’ll try it though. Maybe it’s that simple
I mean at this point I’m open to any potential solution I feel I’ve tried everything
I rode it to work without disconnecting today…
I’ve been on this “issue” for the past 5 days, unbuilt, rebuilt everything like 5 times.
I had considered the remote batteries but my previous one lasted for 30 days without charging I assumed this was the same…
Don’t overcomplicate things.
Well at least this thread may help someone in the future
Thanks for your help guys.
