hey guys, so im trying to get my mini remote set up with vesc tool…however when im at the tab to adjust the pulselengths,but it flucuates up and down about 50% constantly on its own…it seems like i cant get it to zero in on a value…im trying to play with the throttle trim and steering trim knobs on the controller but it isnt proving to be successful…
does anyone have any input on how i should be setting this up?
does anyone else have any idea on what could be wrong? or should i just chalk it up to a broken remote?
its brand new never used so it kinda bums me out if its a busted remote
so tried all channels with a new servo cable, and it still fluctuates like crazy…
im just gonna buy another remote and chalk it up to (hopefully) a faulty unit.
my winning remote keeps giving me dropouts when i get to about 1v away from my low voltage start…so basically whenever im on my way home it can reliably cut out about every 10-20 seconds…causing me to need to either walk or ride veerrrry slow so i dont fall
tried it on 2 vescs (im running split ppm, but i tried to get the controller to work individually on each vesc).
im fairy certain the problem is pointing to either the remote or receiver… both vescs work fine with my other remote (until dropouts, which again is a remote/receiver issue). im just trying to fish for suggestions, or maybe find someone who has experienced something similar.
Did you ever isolate the problem? I’m having a similar issue with very erratic pulselength signal with my TB nano remote. The second I plug the receiver into the VESC things start going crazy. Doesnt matter whether the remote is on or off. This leads me to believe it is the receiver but I’m just looking for additional insight
