This is my first ever build, and I can’t seem to get it to work… I’m using the free vesc project tool. After the battery is fully charged, I connect my vesc to my pc and do the motor set up wizard with the following parameters:
BLDC motor max: 80a motor min: -35a
battery max: 15a battery min: -12a
battery cutoff start: 31V battery cutoff end: 28V
here are the parts I’m working with:
DIY electric Vesc 4.12 with FW 3.4 HW 410 TB 6355/190kv motor samsung 6.0 Battery: https://www.ownboard.net/products/ownboard-electric-skateboard-battery?variant=6940852715562
when I click motor detection, the motor spins for like 1-2 seconds, then the vesc flashes red 3x. I get a failed motor detection result.
I went to vesc terminal and typed in “faults” and got this result. The following faults were registered since start:
Fault : FAULT_CODE_DRV Current : -0.2 Current filtered : 0.0 Voltage : 41.29 Duty : 0.009 RPM : 0.3 Tacho : 6 Cycles running : 1 TIM duty : 435 TIM val samp : 217 TIM current samp : 25533 TIM top : 50632 Comm step : 4 Temperature : 26.51
Fault : FAULT_CODE_DRV Current : -0.2 Current filtered : -0.1 Voltage : 41.28 Duty : 0.009 RPM : 5.5 Tacho : 10 Cycles running : 1 TIM duty : 438 TIM val samp : 219 TIM current samp : 25520 TIM top : 50602 Comm step : 2 Temperature : 26.49
Fault : FAULT_CODE_DRV Current : -0.5 Current filtered : -0.1 Voltage : 41.32 Duty : 0.009 RPM : 3.3 Tacho : 12 Cycles running : 1 TIM duty : 446 TIM val samp : 223 TIM current samp : 25478 TIM top : 50511 Comm step : 4 Temperature : 26.64
Fault : FAULT_CODE_DRV Current : 0.2 Current filtered : 0.2 Voltage : 41.32 Duty : 0.008 RPM : 0.5 Tacho : 15 Cycles running : 1 TIM duty : 425 TIM val samp : 212 TIM current samp : 25590 TIM top : 50755 Comm step : 1 Temperature : 26.90
Fault : FAULT_CODE_DRV Current : 0.7 Current filtered : 0.3 Voltage : 41.28 Duty : 0.008 RPM : 2.7 Tacho : 17 Cycles running : 2 TIM duty : 407 TIM val samp : 203 TIM current samp : 25696 TIM top : 50986 Comm step : 3 Temperature : 26.79
Fault : FAULT_CODE_DRV Current : 0.3 Current filtered : 0.0 Voltage : 41.32 Duty : 0.008 RPM : 2.9 Tacho : 18 Cycles running : 1 TIM duty : 420 TIM val samp : 210 TIM current samp : 25626 TIM top : 50832 Comm step : 4 Temperature : 26.92
What am I doing wrong? Please help!
