Hi! My dual beast 6355 maytech motor setup, with dual focbox and 12s5p has some issues!
( I use maytech standard remote and reciver )
Also i use VESC TOOL!
One of the motors in “fast mode” shuts down? So i can press full throttle in eco mode, no problem, but when i switch to fast mode it shuts off after a while? Like you can hear 100% Throttle, and after 5,10,20 seconds it goes down to like 60% or even less?
Short version: When pressing full throttle in fast mode, motor start slowing down.
Not familiar with the modes on the remote.
But there are temp limits on the VESC that kick in if tresholds are met that reduce performance to save the hardware. It would be helpful if you could give us some logs on the actual event and we could investigate further.
Do you have a BMS for discharging connected? And yes post the vesc setting. I guess you hit some current limit, either the BMS (but should remove power to both of the motors) or the vesc
