Motor for single motor mount kit
Hello,
Can you please tell me if does this motor for Hobbie King single motor mount kit, fit adequately the :
http://www.hobbyking.com/hobbyking/store/_38037__Turnigy_Aerodrive_SK3_6374_192kv_Brushless_Outrunner_Motor_UK_Warehouse.html
Best,
Gonzalo
on that page you link It says Motor has 32mm bolt hole spacing.
this is a diagram of the enertion mounting plate, it’s compatible between 30-44mm.
Thanks for the replay.
Does it mean that the engine is compatible?
I’m not sure that the Diameter is compatible it says 59mm. Is it?
I already have the mount kit here and I had to give back the engine that I got because the shaft and the bolt holes were not ok.
Thanks for your help.
yep, your motor is good to go!
