I have motor mounts for Ollin 5065 motors and 30mm dia center to center (21mm x 21mm square center to center).
Pricing
Clamp for Calliber trucks - 25.00
Motor mount for Ollin (38mm hole pattern) motor - 25.00
Motor mount with 30mm hole pattern - 25.00
If you bought ONE clamp and ONE motor mount together - 45.00 + free USA shipping
The mount is raw 6061 aluminum and comes with hardware for the mount and motor.
It is fully adjustable- I am using 36/16 gearing with 255 belt and the mount still has room so could probably do 265 depending on gearing.
I made 3 mounts for @sl33py that fit SK3 63mm (149kv). The hole pattern was 32mm square center to center.
If he doesnt want them I can sell you one or I can make another one but it will be another week- week and a half to have it made. I’m going to give him a few more days before I offer them up for anyone to buy.
I just sold out of the 30mm arm. I just have the Ollin hole pattern which I think just fits his motors but not 100 percent sure, it may fit others. It is 38 mm diva center to center.
@korryh that’s tempting. Idk his return policy. I was going to attempt to drill my own holes. I have access to a better shop next week. If it doesn’t go so well I’ll most likely definitely be ordering from you.
I have a few mounts left and will be making another order if anyone is interested. I have been doing quite a few mounts for 63mm Tacon and SK3s in aluminum arms and stainless arms. Let me know if you need something different and I can see I can make it. Just did a pair of arms out of .25" stainless per someones specs.
I might be interested in two mounts for 63mm motors. I got @torqueboards v4 mount, but can’t reverse mount it since the angle I need it in is somewhere where the screw holes aren’t present. Should I PM you the specifics, or have you reverse mounted before with 70~mm center distance?
