I am prepared to cut the wires an inch or two back from the connector and use similar gauge copper stranded wire to extend them, is there anything wrong with this method?
(sensor interference/sensitivity etc)
In addition to my sensor wires being short, they were also the wrong connector. Dexter sells an adapter harness that would extend it if you have the smaller connector type, I just cut the wires, bought these and soldered them on.
You guys are dope, good to hear there wont be any issues extending those puppies…
Ive read too many forums and e-board wives tales…
The vescs arent in yet, so I’m not positive my connectors WONT work, but based on Bigboys link I should be able to narrow down what Im workin with once their here.
If they DO fit, ill snip my sensor wires 1-2" from the connector and solder some 26awg gauge wire in between the cut.
Ive got trampa motors, whatever connector they come with, hopefully its just solder, plug, program, play
