Hi There ,
Reacently i’ve upgraded my board with Mountain trucks and 8" wheels , for some reason i dont know why it is very difficult to take simple turns …
I’m pushing to the end of the board limit but the Angle not sharp enough to complete simple turn…
Any ideas ?!![15398873411358429612298350998382](https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/d/9/d9441098e5226e8d33b73458cd53a75bb37ddbc9.jpeg)
![15398874438116173779377219081355](https://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/3X/3/7/37e9cec1aefa3ffa120a51d72eab43181f90f5f5.jpeg)
mmaner
2
Most MTB trucks are at 30 degrees, longboard trucks are at 50 degrees. You need to wedge them closer to 50 degrees to get turning radius.
EDIT: most MTB trucsk are at 20 degrees. Not enough coffee too
They look like theyre on backwards. More pictures please
To wedge them…?! ![:thinking: :thinking:](https://electric-skateboard.builders/images/emoji/twitter/thinking.png?v=9)
Hwo can i achieve 50 degree ?![:flushed: :flushed:](https://electric-skateboard.builders/images/emoji/twitter/flushed.png?v=9)
mmaner
7
you will to wedge them 30 degrees or more. I think @Kug3lis is the only one making them right now, @okp has some as well if you wanna PM him.
Ok got it so the raiser that i resived in the mounting kit not “high” enough… So i’ll try to add other one to add some degrees…
I’ll update here if my simple solution will work … Thank you
![:wink: :wink:](https://electric-skateboard.builders/images/emoji/twitter/wink.png?v=9)
update … i’ve increased the angle by using double riser pads … And now i can take “sharp” turns … :slight smile: thank you for the tip!
