Wondering if the advantage of having motors protected, is worth the effort to redrill and rotate the motor mounts. Do you lose ground clearance or any other drawbacks? Heat, etc?
They can bite the board when you turn if they are on the inside.
So the required clearance (height between board and Hanger) to have them tucked in is more.
