I have set the FOC for the vesc … and build the insenssial for make a run, and work perfectly
I just need put some paper fish and put some thermal adhesive tape, and change my BMS, all this stuff is coming, maybe 1 week, or 2 week.
Calm down, i just drive 10 meters, and I have Heat shrink for separate the batteries (provisory fisher paper)
some picturs:
II don’t know why, but the most of people, prefer put the motor inside the board, but mine go outside, i can put more high, and this make, i have more distance between the floor and the motor
Nice build you’ve got and good that you have chosen a Vesc!
The motor mount that you are using has some records of breaking quickly so if that happens to you this motor mount I can recommend for you (im using it also)
i know, the mount is famous for break fast, but i buy before know that.but i have another one, the mount took more than two month for arrive,and i asked a refund, and paid a second, and 3 month after the first order arrive XD so i have 2 for a price at 1.
Ya you are right, the caliber dont have this problem,i didn’t buy caliber because, i didn’t know if the mount will be to close to the board… I tightened hard, it looks very fixed, my problem is, this mount looks weak.
