Okay man take your time. That black and orange looks amazing.
Should look pro when your done.
Seems a popular option these days to to run the Evolve trucks… me included.
Yeah. Why try to invent something that it’s already out there, right? Gave me what I wanted: wide trucks, stability, great quality, carving ability, drop-thru, double bushings, proven concept and aggressive looks.
Exactly, my goal for my first build is see what could be done with mostly off the shelf parts, that and I’m in Australia so Evolve headquarters is an hour from me.
That’s right. Off the shelf! Go look out there what items you need, I bet there are hundreds that fit your taste. Pick them up, gather the whole enchilada and start assembling your dreamed esk8. That’s what I did. Before starting I searched all websites on the planet. Few months of digesting information, picking here and there, reaching dead ends (like when I was looking for a dreamed alluminum deck, and learned that Dave’s Cindrich will no longer manufacture his Silverfish). Changed direction and followed other paths. Finally I found what I liked, got a nice Hawaiian longboard (Alani Lani) and started from there on.
I started a build thread, check it out.
Wow!! I will devote 1 hour to follow your tread.
Thanks for the suggestion and the links bro.
I’ve been following this thread and it sparked me to use the Evolve GT trucks in my own build. I bought the rears and reversed engineered them. If anyone is interested in the CAD let me know.
Wow!! @gmdangelo There are few measures that we need at the moment.
What is the inclination angle° of the rear hanger related to the horizontal plane to the ground?
What is the witdh of middle hanger’s cross section hexagonal looking edge?
is this the angle you where looking for? if not, could you use a picture to describe it?
i didn’t understand the second question. a picture would help.
Yes, that maybe better. Is hard top explain with words…
If you still thinking of using velcro you should should consider 3M Dual Lock, it’s a turbocharged velcro.
https://www.amazon.com/dp/B00PX22H42/ref=twister_B00QU5SMNG?_encoding=UTF8&psc=1
Also why not use a Evolve front trucks as a rear one with a normal clamp and mount instead of using the rear truck? May be it works. I’m asking bc I also am interested in building my future board with Evolve super carve trucks.
I highly considered using two Evole front trucks myself. In the end, I’m going to use their rear ones with the bracket
Me too I considered that at the begining. But when I had the chance to get the pair of trucks (front & rear) exibited at the local Evolve distributor I didn’t thinked twice and forgot all about getting two front trucks.
I think the image needs to turn 90 degrees to the left (counter clockwise), the plane horizontal is the blue line, right? and right side of the image is the hanger’s top?
If that so, then yes, that was the angle we needed.
