Hi guys, i have just finished making two awesome boards, one for me and one for my girlfriend, my one is dual drive with two 6355 motors and dual vesc my girlfriends one is single motor single vesc. her board rides like a dream but mine is just hard work. it has to much power it wont maintain a constant speed it just keeps pulling and pulling. it also has a little stutter when starting from a standstill.
i have messed with some setting to try and fix the stutter but nothing seems to work. i have the vesc set to master and slave as per information found on this forum does anyone have any other ideas of what could be causing the stuttering? Also does anyone know if there is a setting a can change to make the board more controllable at a constant speed instead of just pulling and pulling? both boards are useing the same controler so i cant see that that could be anything to do with it. my pulleys are 16t 36t on 80mm wheels so i dont think that is the problem.
and advice would be great. im now to the vesc so im still figuring out the settings.
