im assuming you’re wanting to go dual motor? If you want narrow trucks, go with dual 6355. If you want more power and want to use 6374’s, you’ll need wider trucks. Also, imo that remote is a piece of crap. it doesn’t have very much travel so it’s very touchy. And use whichever wheels you want, just remember that smaller = more torque and larger = higher top speed. of course your gearing will affect this too. And the Torqueboards torque esc is a lil cheaper than the focbox unity if you wanna save a buck
Great choices. All goes together perfectly. 218 trucks if you want the 6374 motors. 15mm belts all day long. 97mm wheels because you won’t chalk on every little stone and drop the nano remote. Try a benchwheel or a maytech over that option. Everything else is spot on.
