This is my first diy build mountainboard/longboard style Eboard…
Everything on this board is premium the deck came with battery enclosure but it was not built for 21700 cells or stocking them by 2
SPECS!
Maytech 6396 motors
Flipsky vesc 6.6 plus
Flipsky vx2 remote colored version
Samsung 21700 Battery 12s6p (I ALSO DID THE BATTERY)
MBS matrix 2 hangers
MBS rockstar hubs
Evolve 6” tires
Deck is a 37”x9/12 short deck sharper turns
Will be installing Flood lights
Hey man it looks dope!! I’m currently working myself on my first build (it’s taking for ever !?!) and might get some inspiration from your build. I wonder if you would have been able to fit more batteries if you fitted them the other way around. Hope you can find a good looking motormount that’ll fit those Maytech monsters.
I tried but it’s not wide enough I was gonna put the vesc by it self and make an enclosure for it and do a 13s8p but the enclosure just not wide enough
Update I’m almost done with the build waiting for the moon gear drive so I could order them but I’ll use the belt till there ready still waiting on the bms and wheel pulleys then the build is complete…
