Hi,
With a friend, we are planing to build our own electric skate
But actually we are choosing the hardware of our skate witch will be :
Vesc as controller
SK3 - 6374-192kv or SK3 - 6374-149kv for motor (only one for each board)
LG Chem 18650 HG2 x40 or 48 for each board to build a 10s4p or 12s4p battery in order to get a long range board
36V 60A 12S for BMS
But I don’t know what motor choose to get torque and a long range, and a 60A bms will it suffice to protect the batteries and control the charging process ?
Oh I read it as HE2 - nevermind then. The HG2 will be perfectly fine.
I charge my 10S 18650 pack with a laptop style charger - you don’t necessarily have to have a BMS with Liions. This has been discussed numerous times on this forum - just check some of whitepony’s topics out.
As long as you are conservative in your charge and discharge levels you should be ok. I have a 10s3p made with Samsung 30Q cells with no BMS. Its my daily driver, I charge with a laptop style charger to 41v and discharge to 34v and have yet to have an issue.
Most of my packs have a BMS but lately I’ve been using them for charge only, bypassing them for discharge. There’s always a risk, but if you are reasonably careful you can save a little money and free up a lot of enclosure space.
