Thanks man, yes I am new at here, my board is brand new comes from the factory the Samsung cells is just available to the Pantera. My board have the same aspects . Thanks for the extra information
lmao:joy: 10 char
Gotta say I love that grip tape, that board wouldnāt look out of place if it dropped out of a NASA lander on Mars. Well ware, thatās lovely.
Hi everyone,
I am new on this siteā¦ I have a GX4 2018.08 Bajaboard. I got it 2nd hand with 17miles on it. Unfortunately about 2 weeks ago I decided to tinker with it and take a look under the āhoodā so to speak. I had just finished cleaning out the battery compartment and was putting the 900Wh 30Q battery pack back when it happenedā¦ I did not pay to much attention to this little white & frayed wire coming out from the packā¦ I should have known better (I am an Aerospace Engineer so I am a perfectionist with OCD). so as I was putting the batter back into the bay, the little white wire touched the ācontactorā.
so now I am not 100% sure if my battery pack is still any good or where the this little white wire is to be attached to, but it seems like it is a loop that was not suppose to be out side the battery packā¦ Nor do I know if the mother board is working properly since it seems to keep vibrating on me when I power it on.
So at this point I am giving up and looking to upgrade the mother board to the 2019 MB w/ Tank mode. buying the 1.1KWh battery pack, I am also looking to get the 110A controllers, the 16T pulley. I am not sure if I want to go with their motors just yet. does anyone here have any suggestions on motor upgrades? I want to stay with 6374, but I am not sure which motor would be an upgrade to what Baja is offering since they have not revealed the specs to their motor. I have asked, but they are staying silentā¦
my playground is sunny silicon valley CA where the weather is always nice. and I am looking for more top speed. I use my board to commute to work and everywhere in Santa Clara county.
YES I am used to speeds in the high 30mps to low 40mph. I first started speeding with a VISA Dirtsurfer about 15years ago when only gas was available.
All suggestions on upgrading the motors would be welcomed.
Thanks
Nice set up!
Did you fix it? The only white wires in mine are the temp sensors - they attach to the BMS (soldered directly onto the FETs, to pull them to ground and thus disconnect upon overheat)
