I tried UDP, TCP and had latency issues (maybe I wasn’t doing it right). Tried websockets last weekend but my arduino IDE setup was causing issues. Using these technologies are really only so I can get rid of the RF24 chip/board in my remote.
ESPNow is another thing I tried (I think it’s a websocket)… and BLE, but the BLE/BT stack wasn’t mature with ESP32 at the time (and probably still not there).
Umm… I had some teething problems with nRF24 initially (hardware, not software) and I like the idea of having one less board in my remote (space, complexity). Seems to me that it is the best option (aside from the space needed).
nb: wifi seems to have too much latency in my short investigations.
I think WiFi is not a common thing in real time remote controlers for a reason. I would stick with BT or RF. And I completely agree, having as less HW as possible is generally the best thing you can to your setup. I have said that many times throughout this post and it can’t be said enough times. Having only one arduino in my remote while keeping the board “stupid” by connecting a BT module directly to the VESC made my setup stable.
BT straight to the board. Hmmm… interesting (I haven’t read all the posts sorry).
I do have the option of doing some cool stuff on the board if I have an ESP32 between the remote and the VESC (lights, status indicators, tilt-sensors) but I might have to consider the advantages.
I’m guessing signal strength could be more critical with BT over RF.
Okay, exams finished and I’ve been able to start in earnest.
Here’s where I am at:
CC1101 radios are working - they use a lower, less cluttered frequency (lots of stuff runs on 2.4GHz meaning NRF-based remotes will be more susceptible to interference) that should result in far fewer drop outs and a more reliable remote. The SoftPot is also working as shown in the last gif (top line on display is throttle input percentage)
Ideas can change the world
I am glad to have a part in this, this looks awesome indeed.
You have 3D printer right?
Would love to compare the ride feel between this and the two FSRs I use
I see you use two Nanos, I hope to have this solved by connecting just one Nano in the remote and a NRF (SPI) connected directly to the VESC. BTW if you’re using VESC6.0 it should be supported out of the box.
