They have different voltage. The second one is for lifepo4.
Both of them have very low amp discharge.
Unless you plan to bypass the pack aim for 60 amps continuous discharge.
Luckily i didnt pull the trigger. I found this 10S instead. The reason i was initially looking for an 8S was because the BMS i had prior was HUGE and took up too much space. This one is MUCH better size wise.
Actually i bought one of those. Didn’t weld the pack yet. So i dunno but It was upvoted. I have great expectations about It. Small and waterproof sounds good.
Again…aim for 60 amps.
