Hey,
I’m quite new to the DIY scene and I was wondering if anyone with DIY experience could take a look at this build and determine if it’s worth my 300eur and one and a half hours drive.
The following is stated about the board: Motor: SK3-320kV (max 2220W) Battery: 6S Lipo 22.2V 10Ah 222Wh (max 200A continue) Motor controller: Boat ESC (max 120A continue) Remote: BadWolf GT2B controller. Seller , like most here, seems like a very nice guy so I kinda do trust him.
320kv is a bit much and won’t have heaps of torque. And the boat ESC won’t have good brakes (if not any). 300 EURO sounds ok though, you could change the motor to a lower kv (245 is good for 6s) and change to a car esc or vesc.
It actually looks very nice. But I have had only bad experiences with boat esc’s. And with that motor you’re just fine with flat ground, despite that it isn’t ideal kv.
My first board was almost like this but I used 260kv motor and spend money aprox. 350 dollars. So if you have time and intrest to do it by yourself, then do it, but in the other case this is good choise.
Thank you for the reply:)! I live in the Netherlands so flat will do. I guess I’ll switch to a VESC asap when I notice the boat esc doesnt suffice or isn’t safe enough.
Why don’t you just save a little more money and build a good one, all you have to build is one, im currently building mine with all new parts w/a turnigy sk3 6473 motor and a Vesc, all for under 400 USD. just waiting on charger and mini controller which arrives next week.
