So im gonna build a board and would like to hear the opinion so far on the parts i have chosen, I mostly ride on ok isch pavement and looking for a little bit more torque compared to WowGo 2s i currenty have
Change flipsky motor to one from forum vendors to 6374 if going single.
If you have a sanyo already, get another one and connect in parallel for less sag, more range. Go regular caliber 2, 44/50° 10inch. Go with 15mm belts You can’t use wowgo remote, only with it ESC. You’ll need a gt2b/nanoX/mini/hoyt, etc. Focbox. If not, torqueboards ESC or Hobbyking esk8 ESC.
should probably edit that its going to be dual drive, but your saying the 1 sanyo isnt enough? then it might be just better getting a completely new one i guess, also im not sure about the deck option either since im kinad new to longboarding only ever owning 2 of them
For dual, 40 cells minimum. Deck depends on speed or comfort. Check build threads, to get an idea
how many cells does the 1 sanyo battery have?
Its 10s2p=20
Ok ty so you think that 2 of them would be enough power for dual motors in a build like this?
Specifically 2x 10s2p sanyo 20700b, then yes.
You could probably go dual on a set of caliber is you went with small belts like 9mm BKB has a awesome sale on 6354 motors on black friday.
As far as I know, you’d better use ESC and remote together. If you use Wowgo remote, then use their ESC too.
You must use them together, they only work with each other. Also a good deal on pulleys below
Updated the picture help appricated still. I dont really know what deck i want since i would like to mount the motors on the outside
