I have 2 6S 10C 5200 mAh batteries that are connected in parallel. I am not going for the fastest speed but hoping to get about 20 Km out of it. I was maybe looking for a VESC my budget is around $200 USD for esc and motor i can go over a bit more.
VESC typically are around $100 Motor - 60-120 (DIYes, Enertion have some good 63mm options) - also look for groupbuy and Maytech options for less.
Mount? That might blow your budget, so look at @korryh and see if he has any left? Or enertion or DIYes mounts.
GL!
i already made my own mount and i have the gears and belt. should i get the VESC BLDC Speed Controller and the Electric Skateboard Motor 6355 190KV? i have the tiny remote that I got from a group buy last year.
^ Sorry forget to tag you in the last post
Yes!
10 char
does the torque boards vesc have a power button or switch on it?
As long as you don’t expect “rocket” acceleration, and are lightweight - a single motor should work great for you. Even heavier riders like me can do fine on single - just don’t expect to go up steep hills.
Sounds like a good setup.
A note on motor kv… depending on the voltage (# in series 3s, 6s, etc.) - try to stay below 10s on 190kv or you can have issues with VESC ERPM exceeding 60k (which can/will kill the DRV chip).
If you want to run your two 6s in series for 12s - you’d want the 149 or 170kv motors.
If you have an expectation of speed or hills - it would be good to know your weight and gearing to make sure you are setup correctly. Have you looked at a speed calculator yet?
Not to knock what you have, but 10c batteries are going to SAG - a lot. So when in use you will get less range. Those are giving you a “claimed” output of only 52 Amps (in parallel 104A). I typically would say 100A is my personal minimum - given it’s marketing and likely not able to actually provide the full “C” rating they claim. The higher the actual output capability - the less they will sag when being used more heavily.
To illustrate in case you aren’t familiar with “Sag”:
This shows the affect on increased demand in amps from a battery (these are the venerable 18650 25R’s) - the more you ask, the less mAh/Ah you get from them, and the more they sag to a lower voltage from the demand. Plus more heat - which shortens pack life.
HTH - GL!
VESC dont come with power switches like car escs … would be nice though…but anti-spark xt90 or some type of vedder anti spark switch… or live with the POP when you connect them
No!
10 char
LOL…Mr.Direct and to the point today
Yes!
10 char
