1. Deck – 106.99 (Bamboo Raven) • Material: Bamboo / Hard Rock Maple • Length: 38″ x 9″ • Wheel Base: 25.75″ • Type: Top Mount Double Kick • Trucks: 180mm Black RKP Trucks • Wheels: 70mm 80A Longboard Trans Blue Wheels • Bearings: ABEC 9 Bearings w/ Spacers • Hardware: 1.25″ Skateboard Hardware • Grip Tape: Black Super Grip Tape
2. Motor – 79.26 • Turnigy Aerodrive SK3 • 245kv Brushless Outrunner Motor
3. Motor Mount – 72.99 • Enertion Motor Mount
4. Battery – 108.00 • ZIPPY 5000mAh 3S1P 20C Hardcase Pack (4) • Balance Plug: JST-XH • Discharge Plug: 4mm Bullet-connector
5. BMS – 29.00 • 22V 24V 6S 30A 6x 3.6V Lithium ion LiPo Battery BMS PCM PCB
6. Charger – 21.49 • iMAX B6 OEM Battery Balance Charger For 1-6 cell Lipo, Li-ion, LiFe (A123), Pb, 1-15 cells NiCd and NiMH Batteries
7. Charger Adapter – 11.99 • Simple Charging Port Adaptor • Balance Leads: 4S/6S/8S JST-XH plug • Charger Leads: Deans Connector • Request XT-90 Anti-Spark connectors and battery leads
8. ESC – 70.00 • TorqueBoards 120A 6S ESC
9. Programming Card – 15.00 • TorqueBoards ESC Programming Card
This is my build as of now. I have a couple of questions that I’m unsure about.
- What pulleys, timing belts, and other mechanical parts do I need for this setup?
- Where can I find an on/off switch and battery voltage meter?
- What wiring, connectors, or leads do I need (assume that I have the on/off switch and battery voltage meter)? If possible, can you diagram how the wiring would work?
- Any recommendations on a sleek electronic enclosure?
- Is there anything that I am missing?
Thanks in advance.
