I just start to build my electric state board, but I have a problem that the motor rotates too slow. I adjusted my motor configuration and setting hundreds of times still doesn’t work. Really need some help there.
This is the setting of my board.
I get a Turnigy G160 Brushless Outrunner 245kv (160 Glow) from HobbyKing.
Two ZIPPY Compact 5000mAh 3s 40c Lipo Pack in series.
I also get an Enertion motor controller as my VESC.
Increasing the motor amp will only increase low end torque when duty cycle is low… Once he hits ~37% duty cycle, battery max would kick in (if he sets motor max to 120a). I’ve found battery max to be a much better way to control how much power the motors actually see.
Are you trying to do a motor detection, or have you already done that? If you are doing a motor detection, try taking the belt off.
I have tested VESC with lower voltage (5S) on a 245kv 6364 SK3, and the motor barely turned when I had the belt installed. Running on 8S the motor really showed some decent power. I’ve never had luck with VESC at low voltage like 6S, I suppose a higher kv might work better.
That’s the point, his problem is that they’re moving slow. If he put his batteries in parallel on accident, it would explain that since it’d be below the cutoffs.
No… it doesn’t. Cutoff is the voltage floor for which the power gets reduced. He could set it to 0v and it wouldn’t make any difference as long as he’s actually using 6s.
Once you get “battery cutoff start” power is reduced a bit. Once you hit “battery cutoff end” power is reduced almost completely.
That value is not max input voltage, max input voltage is above that and is correctly set to 57v
