After several months I finally have all the parts I need for assembly. I’ve done a lot of reading on these forums but I would feel a lot better if someone would just guide me through the process via PM or text. I’m willing to paypal whatever is a fair price for the help.
I’m working with the following
-trampa deck trucks and wheels
-Dual 6374 190kv 3200w motors from build kit boards
-12s4p battery from @Eboosted
-Motor mounts, belts and pulleys from @Idea
-596 BMS from Bestech (its the new version of the 223v1 that everyone uses. Should be same specs I believe)
-dual ESCapes
-several different switches, including the $60 one from mboards that has anti spark or whatever on it
-a bunch of extra parts that I probable won’t need.
-I have VescTool downloaded (no idea how to use it though)
Note I have a battery capacity led display that I would like to connect as well. I have multiple power switches as well as a charging port and I’m assuming I should use the safety power switch from mboards which is rated 6v-60v, 120A, and up to 14S. Any reason I shouldn’t use that? Also no idea where to connect it on the battery pack.
2nd pic is showing that the motor sensor wires come up about 2 inches short to the ESCapes. This is fine because I can use the space for the BMS instead (3rd pic) and the motor sensor wires do reach fine if I put the ESCapes topside (4th pic). I’ll worry about getting the ESCapes in an enclosure on the top later. Just want to get the connections set up first and working.
