I’m currently running it in FOC, and have the ERPM limit set to 60000/-60000, as well as under the app tab I have it set to 53000 and 55000. I’m a big guy, 6’2” 230lbs.
Never owned an F-box so bit unfamiliar with how sensitive they are. guessing you’re looking for max and min current values? The default values wont do any harm. But since you got a bick pack you can increase max min quite abit.
If you experience alot of electrical noise from your motors you can play abit with the “Switching frequency” on the advanced tab. 29-32k is usually the golden spot to make them less noisy. If you’re using NRF and have Cruise Control you might have to fiddle abit with the PID values. Think the default values are suited after BV’s prefrences but can be altered if you’re heavier/leaner then he is, also depends on terrain etc.
Try monitor your current draw and see if you ever Close in on any current tresholds. Since its dual you’re pretty much covered with 50A per motor. But I dont see any problem with increasing it a little
I was told by the person who made my battery pack (shout-out to @Brando), “It actually allows bursts up over 100A.” and also suggested 50A for battery max on each FOCBOX.
I have found that 50A always works best for me. The VESC is the bottleneck for most systems and will throttle itself due to heat when nessesary so the battery max setting doesn’t actually matter too much. If you have issues just lower the value.
