My first build. Just got my motors and esc and the motors come with 5 small wires which i assume connect to the hall sensor connection on the ESC.
But the wires are individually crimped and not in a connector that can just fit into the hall sensor connectors on the ESC. I have no idea what sequence the wires go.
Edit: Board finished just need to go buy a planter box for my enclosure
Hey mate is that a complete motor and esc package? I’m only saying because they usually come with connectors attached and are mostly plug and play so someone stuffed up.
If its the sine wave esc then it actually works fine without sensors, just make sure you insulate the wires. You get a bit more torque too but if you want the sensors to work you need a motor guru like @Hummie
ive never made a motor with sensors and probably was only on such a thing for max five minutes. Id cut them off and kick the motor amps way up and forget about it! to each their own.
lately im freaked and next board i put together has to be super reliable. escs are awesome but suck and break. hoping on the 6.6. i dont know what happens when sensor wires fail and maybe its not too bad but im feeling really lucky at this point. even when running two escs if youre hard on the throttle or brake and one esc breaks…im lucky many times now. i kind of enjoy the challenge…like when the brakes die and im forced to pancake onto a car for a moment, gives me a thrill, but completely other than when that happens its a nightmare. And then youre freaked and dont trust your stuff. receivers have sent me with stuck-on throttle…that was one painful event. and once had my main battery wires break while going down a steep hill with 3 lanes of traffic didnt feel good either. everything has happend to me at this point i think. I can trust myself to do dangerous stuff, that’s skateboarding and electric skateboarding for sure, but when things are out of my control game over.
nah it wasn’t a package I bought them separately. No idea if its a sine wave esc or not. I don’t know too much about electronics so I just thought if it has wires it should be connected
I think its the difference between eboarders and longboarders. I would never think of not pushing off to start, its just not in my wiring. Feels weird standing there and relying on the remote to move me. I kind of use my board like a snowboarder uses a ski lift. Its for uphill shit.
im also cheap. that’s why i give a push. partially true. when im not riding powered board like now im pushing the long board around many miles with an empty hole. its a nice board. huge. relaxing.
I would be trying it without sensors and if you get major stuttering from a standstill then work out how to connect them. I don’t personally use sensors at all as they can lock your motor when they go bad and there is too many other things that can do that. I’m a push start kind of guy. Saying that all my boards will start from a complete stop just fine and one has that chinese esc thing that looks very similar to yours.
Hmmm I’ve connected up 2x 3s in series for a 6s battery, its completely charged and when I plug it into the esc, the ESC starts beeping and the low battery indicator on the remote is flashing and wheels don’t turn. The 6s and 7s pads on the ESC are not connected. Do I need to connect the 6s pads with solder for it to work on 6s?
image is not my ESC but shows a picture of the pads that aren’t connected on my ESC
I’m guessing your in Aus too by that awol deck. If you can get down to a Bunnings they have some rectangular plant potters that have served me well, and you too until you get another case. I think they were $4
Yeah I am in Aus, was planning on going down to Bunnings cheers will go straight to the garden section, might wait till Saturday though, sausage sizzle
The hall sensors tell the vesc where the stator is and when one goes it confuses the poor soul and in the case of my HK sk8 very recently it locked it solid. Luckily I was on the flat and ran it off. I think that if I was travelling a bit more it would have continued to run but I’m not game to test that theory. Disconnected and reprogrammed and haven’t noticed the difference at all with the way I ride it so all good. Still going to squeeze a new one out of hobbyking though lol
@pat.speed@trinidad saturday morning ritual. always find a reason for a bunnings trip. double saus and onions and wander round the shop dropping it all over the floor. Just bought a small planter for my vescs because the @TinnieSinker new battery has maxed out my enclosure. Function over form but hell whatever works while you’re waiting for machined version!
