My bearings are loose in my Six Shooter hubs, causing a clicking / rattling noise while riding at any speed.
They easily pop off when removing my wheels. Would lubricating the hub housing help? Or would gluing the bearings in place work (that sounds risky to me as the bearings would be stuck there if I needed to replace them). Or do I need to get replacement hubs?
I would NOT recommend lubricating the outer bearing or the hub that it seats in.
This could only exacerbate the issue.
I would try a different bearing (NOT REDS). This issue has been also covered with the ABEC11 Superfly 107’s
What you are hearing is the wheel likely sliding left and right on the the bearings (if that makes sense). With the wheel completely bolted to the axle you can probably grab the wheel and forcefully move it left and right, or caster or camber the wheel (which it should not do).
Some people have tried certain types of locktight on the outer bearing and hub. Also, shaving the spacer a little with a file to make the spacer just a hair shorter as to allow the bearings to fit tighter to the hub once bolted.
Hope this helps…
I’m a victim of loose bearings (on 8" hubs), too. I can feel your pain
For this issue I use kapton tape which is only 0.04mm thick. If the bearing has play all around the bearing in the hub start with one layer of kapton tape (no overlay), if needed add a second. In my case it’s almost on 2 sides only so I’m adding shorter stripes. This works also great on keys which wiggle in the keyway of the shaft or pulley. Kapton tape for the win! But it is important to have it almost pressfit, otherwise the tape will move later.
This is what I did on some hubs but don’t file too much. Insert the bearings and spacer first and press them together with thumb and trigger finger. Then try to push and pull with this hand to see if the bearing moves sideways. If this is the case then the spacer is too long. If the spacer is too short you would squeeze (harm) the bearings when overtighten the nut.
I typically take the wheel apart to remove bearings. There are bearing pullers, but the whole process is a PAI since there’s a spacer in between that is the same inside diameter.
