Sander
December 12, 2016, 4:50pm
1
I am currently making a new E-Board that will have the Carvon Dual 2.5V.
Batteries are Li-Ion 18650
Bat. Spec: Max.
Continuous discharge current: 20A
Nominal capacity: 3000 mAh
Nominal voltage: 3.6 V
I will have them in 12s4p.
So my question is which push button/switch is suitable for high voltage and high current?
The voltage will be over 44 volt and current maybe 50 amp.
Sander.
lox897
December 12, 2016, 9:52pm
3
You could use an XT60 antispark or a vedder sparkswitch ( pretty sure @DeathCookies sells kit in EU). Or TB’s switch.
Sander
December 12, 2016, 10:05pm
4
The vedder sparkswitch looks awesome!
How does it work? Is it with a push button to start?
lox897
December 12, 2016, 10:24pm
5
The mosfets act as a switch. You can use any switch but I think it has to be latching and DPST or something like that.
Did you get the V2.5 already?
The V3 will be out on 3 months from now, do you know what would be the improvements over the V2.5? As far as I know the the V2.5 can also hold an ABEC 11 wheel
saul
December 13, 2016, 8:52am
7
v2 and v2.5 need highly modified flywheels for the motor. v3 can use unmodified wheels and it has a different motor, possibly new trucks…
And for power, a anitispark switch is the nice way, i would still put a loop key in case something goes wrong, you’ll have a quick battery cutoff.
Sander
December 13, 2016, 9:46am
8
I havent bought it yet so I will probably wait for the v3
Sander
December 13, 2016, 9:48am
9
They said it will not be a hub motor any
more in the description of the video
